It is on the extremes of lock, however when reversing it occurs earlier in the steering wheel travel. It only bangs once per turn rather than grinding/ banging throughout the motion.Is it while you are turning or only when you hit the lock stop ?
Cheers @StudleyGlass, might get it into my local fella before taking it to the incompetent stealers.I had a knocking/banging the other week on my front end of mine, call in to my man on the way home that night and he got it on the ramp and within a minute spotted the top bolt on the drop link had worked lose. I could not feel anything though the steering from it or the suspension, it just sounded like you get when a exhaust come lose and knocks on the body.
The knocking only happened on manoeuvring or if i went over a pot hole so to speak. May be worth investigating @DaveyB . Just a thought![]()
Bear in mind it was my T5 and the trim may be different......but, from memory, the universal joint was hidden behind a shroud at the bottom of the steering column. This had to be removed to get to the UJ which was situated as the steering column disappeared through the floor. In order to remove this shroud, I removed the big flat piece of trim under the dash. Again, assuming it's similar to a T5, it'll be obvious to you as soon as you look under the dash. I had to do it 2 or 3 times a year.....but it only took 20 minutes or so, start to finish.....dead easy. Hope that's of help?What is uj and how do I get to it?
My 2016 t6 diesel Long wheel base four motion is making the same noise /vibration/ rumble when manoeuvring slowly and turning the steering wheel slightly left or right I've taken it back to the VW dealer ship they tell me all late-model transporters have the same problem ,considering the amount of money you pay for these vehicles it Is just not good enough I'm out of warranty in a couple of months I'm considering giving my problem over two John Cadogan on YouTube he really loves the VWs
Did you ever find out what it was?! Sounds exactly what I have!My 2016 t6 diesel Long wheel base four motion is making the same noise /vibration/ rumble when manoeuvring slowly and turning the steering wheel slightly left or right I've taken it back to the VW dealer ship they tell me all late-model transporters have the same problem ,considering the amount of money you pay for these vehicles it Is just not good enough I'm out of warranty in a couple of months I'm considering giving my problem over two John Cadogan on YouTube he really loves the VWs
