albertinno
Hello. I need help with coding.
I installed a new steering wheel with the code: 2H6419091 and the steering wheel is missing gearshift paddles.
Then I also replaced the airbag wiring harness:
Then I connected the necessary wires to the BMC and also ran the power cable there.
When I started coding, I found two places where I added checkmarks:
I also found a place for the cruise control, which was already active. I have the cruise control together with the turn signal lever.
After coding, the situation is like this.
The buttons on the steering wheel and the horn started working. But the problem is that now the cruise control no longer works and the car gets an error that it cannot connect to the gearshift paddles on the steering wheel.
Now the engine light also started to come on and the dashboard shows that the cruise control is activated. When I press the buttons, nothing happens.
What could be the thing I should do to get this cruise control working and get rid of these errors.
Regards Albert
Regards Albert
