Step by step guide to removing DPF
pmblue57
Hi I’ve decided to do things properly. I hear about deleting the DPF, EGR and adblue but they come with problems not to mention the possibility of emission rule changes and having to put it all back to standard one day.
So I need to remove the DPF and have it checked and clean if possible. Is there any step by step guides available on how to remove the DPF on a 2019 2.0l T6?
Much appriacted
The engine management light has been on for around 6 months. I’ve removed the EGR valve and cleaned it thoroughly, I’ve even had the map and deletes removed and gone back to standard. Local garage said the DPF is blocked but not sure how bad and whether it would benefit a clean or replacement.
As I’m not a full member I can’t see the link ¯\_(ツ)_/¯
Reactions: mmi
Any idea what's the fault which has turned on the warning light? Have you read fault codes in the engine?
