Good start. You must have it done by now.And so it begins Xmas out the way out comes the silent coat and dodo.
So far it has taken 16 panels of silent coat to do this rear panel and wheel arch , time for a nice big fry up for lunch then back to it
View attachment 3797 View attachment 3798 View attachment 3799 View attachment 3800 View attachment 3801 View attachment 3802
Thank you for the kind words @Fish nice to see another Shropshire t6 owner on hereExcellent effort.
I've only got those same issues to look forward to tomorrow.Thanks mate, I have just been thinking I should start mine now.. especally after seen you start.. but I too have had inlaw troubles..
@Pauly would there be any need to silent coat and dodo thermo liner the floor of the kombi or is that over doing it ?It only rests in place so lifts right out but in the rear you need to remove side steps and rear seats and same in the front, steps and seats, not sure about handbrake though and I did side at a time and didn't remove totally
I've used the full 40 sheets of silent coat up but got a fair bit of dodo thermal liner left might double up the insulation on the sides then to use it upI did mine but mainly because i bought too much stuff so used it up on floor, i cut strips of silent coat and put in the 'troughs'
If you put thermal liner down the floor mat wont fit properly, it lifts the flooring and because the edges are slightly chamfered it leaves a gap all the way around
I've also got a diesel night heater to fit if I get time before I go back to workFine job your doing there sir. It will be well cosy for the family
How's that paint protection is it easier to clean and does the water bead well on it m8
It's on me list to get done I've been busy spending my overtime money on the van ,insulation, diesel heater ,mud flaps and swivels .No rest for you then kid
Yes all seems fine with the coating. I have done 2 cleans (even tho the roads are black!) cleans of fine to a nice finish, paint still looks good still. I have found that when it rains it wash the sh$t off, but as you no its a mess out there at the moment.
