Had it up on the ramp yesterday, took shocks off, they seemed fine... and the mechanic confirmed that, so then we decided maybe the adjusters that sit in top of the springs was knocking, because it’s metal on metal, and the weld points on the floor of the van where the top of the adjusters sit could be rocking/knocking due to not being a flat surface maybe ?
So I took them out, and replaced with original rubber top mounts, so no metal on metal.. it lowered the van a tad more lol... so then I put shocks back on, and guess what, NO CHANGE! Sooooo tomorrow evening we’re gonna swap the shocks for originals,
Noticed little dimples where the top of the shocks sit, from weld points the other side of the sheet metal where they’ve welded the square nut on, however no rubbing on this was noticed. I hope whatever it is, it’s not an expensive fix
How many times have the bolts been out and tightened back up again? I only took mine out twice and they were about 2mm stretched than the an original new set ...VW recommend new bolts each time there undone and torqued to the correct setting as the top and bottom are different
