I'd be more worried about the horrible red marks on your headlining...
Sorry, couldn't resist
Are the captive nuts still in position so you can retrofit
I've got a pair fitted, one for each side
Yes I believe the holes are there on all vans, you do need a mounting plate that bolts to the van body then the glasses holder/handle screws to the mount plateAre the captive nuts still in position so you can retrofit
You have to thrash your passengers and teach them to use the grab rail on the A pillar.Until a passenger uses the holder to lift themselves into the van
@Gwyn may know whether there are captive nuts already present, as he asked a similar question a few months back. If that’s the case, you’ll just need the spectacles holder and a metal mounting bracket
I think the head lining needs come out for the bracket to mount the sun glasses holder onto first !
I could be wrong ??
Sorry I’m still non the wiser@Gwyn may know whether there are captive nuts already present, as he asked a similar question a few months back. If that’s the case, you’ll just need the spectacles holder and a metal mounting bracket
