Springer13
Hi, you guys running with Cooper Discoverer R/T3 235/65 R17, what tyre pressures are you running them at?
Hi, I was going to have the Seikel raised suspension kit fitted to my van which includes
235/65R17 108H tyres being fitted to my standard wheels, they tell me that if they do s speedo adjustment to match these tyres that there is a possibility that the cruise control will stop functioning completely!
Oh and welcome to the forum.T32 TDI 150/map180 with 420 torques 235 65 17, 20mm spacers and no rubs etc, +25mm raise, clearance remaining 10mm 6% rolling radius and the speedo is true rather than a bit optimisic. Softer ride is good, not noisy but you stay slightly longer in the gears and 6th is only on the motorway.
Falken Wildpeak
Thanks. I’m running same size General Grabbers. Only for 5 days so no advice unfortunately. I am running lower than you, so will try an increase today and report back....Hey, no didn’t get any reply from this helpful group () so bit of trial and error which is still ongoing!!! I’m currently running the front at 45 and the rear at 39, seems to be driving a lot better than it was which was a lot lower psi, Im just about to increase it slightly to see if it makes the drive any better. I take it you have the same tyres, what you running at?? Any advice???? Cheers
