T32 DSG 4Mo Staggered 20” Tyre Pressures??
Not sure how true it is but I’ve read a few times 4motion you need to keep tyre size same all round (not sure on technicalities but I assume it’s to do with how the 4motion works and differing resistance from different size tyres)
Its to stop the diff over working
For a 20” wheel 36-40psi. No higher. We’ve done hundreds of thousands of miles in our fleet playing with tyre pressures over the years . 36 when unloaded and 40 when loaded works best. Make sure your alignment is spot on too to get the best out of your tyres.
We are on 20” but 235/35/20 at the front then 245 at the rears. Would you recommend the same psi as were slightly lower on the front?
That’s a tiny front tyre and surely not rated? On our 255/35’s we run 42 all round
