For fronts go 9 and et40... I know because I have one and fits perfect over the t32 brakes. I may get another one instead of running the 9.5 et45.
Rears you can go wider
Thanks gents! Appreciate the help!
Plan on putting the winters on tomorrow so can check to see if the 9 is fine on the rear if you want. It’s a Judd t311rThanks gents! Appreciate the help!
Yes please! That would be great if possible!Plan on putting the winters on tomorrow so can check to see if the 9 is fine on the rear if you want. It’s a Judd t311r
Hi!
I'm waiting delivery of a T32 and started to look around for a set of Wheels. Feels like jumping down the rabbit hole trying to find out what is load rated and not, what fits and what doesn't. Seems to be quite few that have gone for the Judd T311R's - size 20". Question: What size ET would be best on 9" rims? ET 40-45 should be no issue + 265/40 tyres?
Second option I'm looking at: Zito ZF01. Looking at the same size here as well I guess, anyone here with experience?
@old_o ... I'm on 20 x 9 with ET45 rims and 275/40 on -40mm springs on a T32. Sits nice. So if you go 265 / 40 you'll be fine with no rubbing.
Especiallly for you lol
Plenty of space with a et40 9j on the rear and these work fine on the front so it’s down to if you want a staggered look
Options wise 10.5 is the most, mine are at et45 but I use a 5mm hubcentric spacer so go for et40. Mind it’s tight as hell in a 10.5 so you’d want adjustable rear bushes but that’s if you want to run lower.@Keaney Wow! I am really, really greatful for the help you have given! True, might want to go for something a little wider in the back.
@BognorMotors The help here shown by you and the others is amazing. Well, I’m all set on these wheels. Need to figure out if I want a wider rim in the back or not.
You guys rock!![]()
Hi, do you run standard suspension?Bryn,
They are :
8.5x18” Wolfrace Eurosport Munich Gloss Black £135.75 from Circumference Wheels, Walsall (speak to Duncan...brilliant chap)
and General Grabber AT3 225/55/18 109 load rated so well over spec'd for the T32...Bridgnorth Tyres, about £105.00 fitted.
Totally tranformed the harsh ride of the original 17s and perform really well in the snow and in the fields. Perfect fill i think in the arches and width is spot on.
Cheers.
Yes mate. No lowering here as I'm off road some of the time.Hi, do you run standard suspension?
I've got the Axe wheels and think they look great
I'll probably get them painted differently though
