Hi all,
In short I have a dual sensing VSR wired up from starter battery to leisure battery.
I also have one of those AiLi battery monitors which uses a shunt wired up in series on the ground side. The monitor seems to work fine with my loads on (just a fridge, some lights, usbs) showing a draw on the leisure battery.
When I switch the engine on, the VSR engages as described, but the monitor doesn't show a charge coming in. It occurred to me I probably have it wired wrong. The monitor will only see what goes through it...obviously, right?
I wired my VSR in before I decided to buy the monitor. So the connection between the two batteries is the usual way for T5s with a +ve cable under the floor, and an earth strap from leisure battery negative terminal to chassis. But then I added the monitor in series from the leisure negative terminal to my loads without thinking much about it.
Surely, this means the monitor has no way of "seeing" the charge from the alternator?
A closer look at the instructions for the monitor shows C- (charge) on the P- end of the shunt also. Is this what I have neglected, that my VSR circuit negative should also be routed through the P- pole of the shunt so the monitor can "see" the charge?
Anyone able to help me here? I think I've realised my mistake, but I don't want or need the monitor to show me anything other than charge to and from leisure battery, If I send a cable from the P- pole to the chassis, to complete the VSR circuit through the shunt, am I at risk of causing any other problems?
Many thanks again for helping a fool out,
