T6.1 - Adding rear Speakers
can i add two additional 4ohm speakers in series from the front door speakers?
not too bothered with fade and balance at the moment.
would wiring them in series work or am i missing something ?
Why wire them to the fronts when there is spare pin outs for the rears ? Easy to do
If you wire from the back of the OEM equipment you have to code the device and depending on where you live there are not many workshops that know how to do this process
Only to get the fader working.
Only a small percentage of factory headunits need the rear outputs switching on, most work straight away.
coding is required for fader on all
Could you sort some of the pins/connectors required to add the rear speaker cables?
Mine is a startline, basic headunit... so am I right in thinking the amp, etc. is attached to the rear of the screen?
Drop us a p/m or call and we can sort some for you
