I think I will wait and put better bulbs in the standard lights for now!LED bulbs in reflector lights maybe brighter, but they scatter light all over the place.
Those Vettara ones are pretty expensive for what is basically a pair of cheap bi-projectors and HID kit retro-fitted into halogen reflector lights.
It has been mentioned elsewhere on this forum that THQ are working on providing projector headlights for the 6.1. The T6 ones are excellent with the right choice of bulbs, so personally I'd wait for them.
Did you get an answer ref the headlights, as I want to change mine.Anyone tried fitting these Transporter HQ LED bulbs to a standards factory fit H7 light in a 6.1 yet?
H7 LED Canbus - HQ Bulbs
Our H7 LED Canbus bulbs have had significant time and energy put into perfecting them, so that they are bright, but not dazzling to other drivers.transporterhq.co.uk
Their video implies they will work as retrofit on standard 6.1 lights, but their product info says its only for THQ lights, and I don’t think they make a headlight yet for the 6.1.
Anyone tried these out yet in a 6.1?
Hi James,Hi All,
Thought I would share with all those with halogens, as they are terrible...
I recently replaced the halogens in my T6.1 - fitted the H7 LED bulbs from THQ and H15 LED bulbs from xenon online.
Both work well with no warning lights or issues. The difference is amazing....
Thanks for that. ”bumper had to be removed” rules it out for me! Will discuss with my local friendly garage …..Hi there,
No problem, links for the bulbs below:
H15 LED DRL / Main Beam Bulbs (Pair)
Our Canbus H15 LED Bulbs are capable of not only producing a brilliant white light for the DRL function, but we have also developed this item to provide you with a extra bright white main beam too.Most other H15 products available on the market are only capable of offering the DRL function...www.xenonsonline.com
Unfortunately I didn't fit them, they were fitted by a mechanic friend. He did say the bumper had to be removed to fit, but it wasn't a big job.
Hope this helps.
They removed the bumper to fit Headlight bulbs? Why?Hi there,
Hope this helps.
How is the beam pattern? Any photos you can share?Hi All,
I’d also be keen to know if anyone tried these bulbs in the standard T6.1 H7 headlightsAnyone tried fitting these Transporter HQ LED bulbs to a standards factory fit H7 light in a 6.1 yet?
Hi Tommy, is this on your T6.1? How are you liking them?They removed the bumper to fit Headlight bulbs? Why?
I changed mine without removing the bumper.
I fitted these from Amazon. Alot cheaper than most out there and I've had zero warning errors or issues with them. Been fitted 6 months now
