I can imagine. I recommend them, they are very bright and the DRL look cool too
Hey @T4goneby have you seen this thread T6.1 LED Headlight retrofitH15 Loom
This was what I ended up with
Ok for closure on this thread as someone else is bound to look at in the future and wonder what’s what….. long and short, they now work. Communication and the way Xenonsonline talk to there customers is appalling, and definitely can’t recommend, however, the lights now work.
To get to this stage, you need to purchase an additional wiring loom, which is not mentioned anywhere in the advert. I was eventually sent a link to a loom, with zero description, zero instructions or wiring detail, just a page and a product. It was another £5 or so I think, for the sake of trying it I thought worthwhile rather than paying to return the bulbs.
After messing about for a while, with connections in different configurations, it’s working. No errors on the dash, drl and sides working as they should and then full beam. Can’t comment on performance as yet as it’s not dark and I’ve not yet used them.
They are also the whitest light I’ve found which is what was expected, so providing they last and no further issues. Chapter closed. Will try and get some images added for info.
Hey @T4goneby, how did you fix the wiring loom into the car wiring plug?Ok for closure on this thread as someone else is bound to look at in the future and wonder what’s what….. long and short, they now work. Communication and the way Xenonsonline talk to there customers is appalling, and definitely can’t recommend, however, the lights now work.
They’re well worth it, I went for they’re h7 bulbs too, they’re really bright .Cool. They're a big investment from Australia so I really want to be sure they're worth it.
Thanks.
They’re still on my options list - although I’m hoping the LED bulbs I fitted today will be all I need. I’ll know that after it gets dark tonight.They’re well worth it, I went for they’re h7 bulbs too, they’re really bright .
Hi @T4goneby - Are your LED headlights working ok - including hi beams on long drives?Ok for closure on this thread as someone else is bound to look at in the future and wonder what’s what….. long and short, they now work. Communication and the way Xenonsonline talk to there customers is appalling, and definitely can’t recommend, however, the lights now work.
I got the same bulbs from xenons online and used the ”loom” to switch the wires so they seemed to work and gave no errors.
It’s only this week that we finally drove more than a km on high beam and after about 15km my T6.1 van started saying to check the main beam bulbs! I’ve used OBDeleven to change the bulb type to every LED option I can find but they still trip the error - not immediately - just after 5-10 minutes! Bloody annoying.
I need to work out if the dodgy loom is not tight, or if I can find other bulbs, but H15 LED bulbs are very rare in Aus.
I’d love to hear if someone has had this problem and worked out a reliable fix.
Frustrating is right!Yeh fortunately mine have been ok! Must be frustrating.
I think the only thing I may have done differently, unless you did the same, was making sure all the connections between the loom and the existing wiring, and the connectors for the bulbs, were taped and wrapped. It all felt like there was potential for them to vibrate loose when I was installing it, so gave it a good amount of electrical tape and wrapped all the bare connections etc.
They’ve been ok since, I’ve done a decent amount of driving with full beam on, currently have the DRL’s switched off, but had no issues.
I think at some stage I will cave and get some alternative headlight units with LEDs, but still not convinced on the look of either smoke or chrome Units from THQ and the OE are just too much at the minute.
Hope you get it sorted soon
What seller do you recommend, in case I decide to try a 3rd bulb type. Have you tried different H15 bulbs?Yeh very similar feedback to me on Xenonsonline. I’d avoid. I’ve found other sellers have the same kits and bulbs for a fair bit less, have a few other bulbs to install over the coming weeks so will update this with a bit more info when I have done.
Yep - the earth and high beam pins are reversed in the T6.1 compared to a standard H15 bulb spec. That’s ok for a halogen bulb but not for LEDs, as you’ve said. So it’s possible that any of your other LED bulbs would have worked ok if you’d reversed the wires, or they might still have given errors.I just bought a pair of H15 from the brand D-Lumia from Amazon which said canbus error free. This was my third set of trying as none of them worked but i could all send them back from the cheapest set to a pair of €170,- none of them worked. Since i could not return this Amazon ones i started fooling around as in the car they only came up as error and nothing was working, so i wondered since it’s an LED which is a diode i tool the plug out of the headlight measured which pin was what and found out you need to swap the 2 outside cabels on the connector and then they work fine with no errors. I was almost giving up and looking into ordering original headlight units so this saved me about 1500 now. Basically if you want to check before f***ing around with the cables just bend the middle pin on your LED light a little backwards so it comes closer to the backside pin turn your lights on and plug the bulb in the connector basically you put your LED in backwards on the plug if the light works just open the connector swap the 2 outside wires from place bend the pin on your LED back to original and tadaaaa ot works
Genius tip this: was tearing my head out with nothing lighting up and only error messages!I just bought a pair of H15 from the brand D-Lumia from Amazon which said canbus error free. This was my third set of trying as none of them worked but i could all send them back from the cheapest set to a pair of €170,- none of them worked. Since i could not return this Amazon ones i started fooling around as in the car they only came up as error and nothing was working, so i wondered since it’s an LED which is a diode i tool the plug out of the headlight measured which pin was what and found out you need to swap the 2 outside cabels on the connector and then they work fine with no errors. I was almost giving up and looking into ordering original headlight units so this saved me about 1500 now. Basically if you want to check before f***ing around with the cables just bend the middle pin on your LED light a little backwards so it comes closer to the backside pin turn your lights on and plug the bulb in the connector basically you put your LED in backwards on the plug if the light works just open the connector swap the 2 outside wires from place bend the pin on your LED back to original and tadaaaa ot works
