Upgrade your existing VW Transporter T6 or T6.1 (Tailgate) with the awesome LED Rear Lights that are available on the higher-spec VW Transporter T6.1's.
Hey, I have 2 slightly damaged tail lights (bike rack fault). Original LED T6, have a 2018 Ocean. Found a used pair of T6.1 LED. Are these a straight swap? Found many threads about halogen to LED, but not LED to LED, T6 to T6.1.
If you are upgrading from standard halogen lights then one wire hole is empty on each side as theres one one foglight and one reverse light
I assume the 3m wire is the cable to run the feeds to the opposite side so you have fog s and reverse on both sides
Get the newest look for your T6 with these superb looking LED rear lights. Suitable for all models of T6 with LED rear lights from factory 15-19 T6 tailgate led rear lights (T6.1 style) Full led rear lights Exclusive to Travelinlite Superb quality & fitment Dynamic / (sequential indicators)...
Don’t you just love finding bodged wiring on your own van. Rear led light 6.1 upgrade resistor attempted install. People only because it works doesn’t mean it’s correct or safe. I only found this because of an intermittent fast flashing indicator meaning resistor was losing connection.! All...
