T6.1 Multivan Wheels
Japseroony
Hi Folks
Tomorrow I pick up a new Multivan Style that has the weird 19” alloys on and I really would like to a, reduce the wheel size and b, find a better AT tyre.
Anyone on here know if wheels such as the Devonports will fit the new Multivan or what alternatives there are?
According to various wheel suppliers, they are 5 x 120, so the bolt patterns are the same. Whether they will bolt straight on will depend on the centre bore, offset and brake caliper clearance. @BognorMotors will know the original wheel specs, so you can do your calcs once you know those.
The Multivan has a different setup to the transporter, width and offset wise - from memory they have to run a narrow wheel - I've just looked up here for confirmation - The factory 17" size is 6.5 x 17 ET60. See here OEM wheel
If his 19's on the Multivan are 8 x 19 ET58 with a 245-45-19, according to will they fit 7 x 17 ET55 Devonports with 235-55-17's will be a pretty similar fit.
