1078788 - Rear Left Parking Aid Sensor - B1076 04 [009] - Internal System Fault
1079044 - Center Rear Left Parking Aid Sensor - B1077 04 [008] - Internal System Fault
Many thanks @mmi
Dealer said it was a connector fault when went in last time. Is there a common connector for both of these behind the bumper or individual ones?
Parking aid/park assist system wiring diagram VIP Membership is required to download this document
www.t6forum.com
However, the "Internal System Fault" bothers me a bit as "normal" sensor faults report usually something else, e.g. short to ground, no signal, etc. See more here
Address 08: Auto HVAC (J255) 9480753 - Control/Display Unit for Rear Climatronic B10AA 31 [008] - No Signal Not much information available for this; it would seem to be a temporary communication loss with the rear climatronic unit.
@mmi mine has the camera & auto parking aid as well not just the basic beepers if that makes a difference
It also has factory towbar.
I have checked the wiring behind the bumper which seems intact & also found this plug in the D pillar which looks ok as well. Unless it’s not the correct one?
You could check wire colours vs. pin numbers vs. wiring diagram. However, not likely the cause.
Anyways, the fault explanation "Internal System Fault" seems to imply in plain English "Sensor Faulty". If you really want yourself to trace this, the obvious next move would be to swap a sensor from left to right and verify the fault follows and one of the above clears.
Instead of the fault codes above would expect to see:
Ok many thanks @mmi I think this is looking like another trip to the dealer. This vans electrics seem to be jinxed. ADAS is hooped, SOS errors…etc etc.
