T6.1 rls rain light sensor assembly
I'm not sure if you need to add anything any more - please check below "complete" wiring for the light switch.
Do yo have them all now (after the foglight retrofit)?
However, possibly need to tweak the adaptations....
according to the template you provided I have checked all the links They are all connected. Only the place in the picture is empty. Do I need to pull a cable according to this situation?
Looks good - the pin 7 should be empty as per wiring diagram :thumbsup:
the sensor didn't work
What didn't work? Lights or windshield wipers?
I would try these - (note the"????" - not sure about that on your van)
IDE08786-MAS10528-Assistance light functions-Rain light sensorRain light sensor
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAPpresent -- ????
ENG148493-ENG149042-Windshield wiper-rain_sensor_functioninstalled
ENG148493-ENG149238-Windshield wiper-Regensensor_aktivierenactive
rain and headlight both not working
I can do it with vcds but with Obdeleven there is no information I can understand in subsystems
Please post full VCDS Auto-Scan
and
BCM (09) adaptation map - VCDS > Applications > Controller channel map > Address 09/ Adaptations/ CSV file
09 Central Electrics
System description: BCM T6PA Std+
Software number: 2Q5937090
Software version: 0935
Hardware number: 2Q5937090
Hardware version: H10
Serial Number: 01102001000495
Faults:
B126A29 - Headlight switch
Incompatible signal
sometimes
Priority - 4
Fault frequency counter - 4
Adaptation counter - 108
km-Mileage - 20902 km
Dynamic environment data - 10000504007777
date - 2022-02-06 01:28:18
B121F15 - Left fog lamp bulb
Open/Short to positive
static
Priority - 5
Fault frequency counter - 1
Adaptation counter - 66
km-Mileage - 20904 km
Dynamic environment data - 1000050800947E
date - 2022-02-07 01:58:40
Reactions: mmi
and
Code:
Thursday,10,February,2022,10:18:21:22112
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 21.9.0.2
Data version: 20211205 DS330.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZLH035899   License Plate: 1121
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 15 17 19 44 52 5F
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 RS    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9971
   Revision: 23301001
   Coding: 001940144324050900000000000000000000000000000000
   Shop #: WSC 00012 790 00041
   ASAM Dataset: EV_ECM20TDI03004L906056RS 005008
   ROD: EV_ECM20TDI03004L906056LE_005.rod
   VCID: 0FC73F7376AB6C9168-805A
   VINID: 9E606AAAA1D8A9C6000C5209245E543245
No ASAM data for: "EV_ECM20TDI03004L906056RS" (VN46)
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7LB 614 517 A    HW: 7LB 614 517
   Component: ESC_base      H01 0700
   Serial number: 08512521191127
   Coding: 11552452484AE68A885C24AD126F670638202078
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
   VCID: 3EF6C1C032BE46EEE0-806A
No ASAM data for: "EV_Brake1ESP90iBOSCHVN46X" (VN46)
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 7LA 907 426     HW: 7LA 907 426
   Component: AC Manuell    H01 0502
   Coding: B03010000810000001000800504001050000000000010000800000000000
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: EV_AirCondiBHTCT6PA.rod
   VCID: 5501B31D9E0DD08F18-8000
No ASAM data for: "EV_AirCondiBHTCT6PA" (VN46)
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01102001000495
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205.rod
   VCID: 742075A21AA00A5410-8020
   Subsystem 2 - Part No SW: 7L2 959 405     HW: 7L2 959 163
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000036899262
   Coding: 130000
   Subsystem 3 - Part No SW: 7L2 959 406     HW: 7L2 959 164
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000036877376
   Coding: 090000
No ASAM data for: "EV_BCMA0" (VN46)
2 Faults Found:
8714 - ROD - Unknown Error Code
          - 00 [009]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 68
                    Mileage: 20957 km
                    Date: 2022.02.09
                    Time: 17:54:55
919560 - ROD - Unknown Error Code
          - 00 [008]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 108
                    Mileage: 20957 km
                    Date: 2022.02.09
                    Time: 02:47:51
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-283.clb
   Part No SW: 5QA 919 283 E    HW: 5QA 919 283
   Component: PDC 4 Kanal   H08 0061
   Serial number: 000150059319352
   Coding: 0601050001
   ASAM Dataset: EV_EPHVA14AU3700000 009044
   ROD: EV_EPHVA14AU3700000_009_VW37.rod
   VCID: 4CF8A53A7A781A4C50-8018
No ASAM data for: "EV_EPHVA14AU3700000" (VN46)
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    015 0506
   Revision: --------
   Coding: 800080000000000040000000000C00000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 7F375F83367BCCA1E8-802A
Address 17: Instruments (J285)       Labels: Redir Fail!
   Part No SW: 7LA 920 741     HW: 7LA 920 741
   Component: KOMBI         205 6750
   Coding: 07A50A022080000801087A000401000000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 7B2B478F064FF485C8-802E
No ASAM data for: "EV_DashBoardVDDMQBAB" (VN46)
1 Fault Found:
16777022 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 68
                    Mileage: 20957 km
                    Date: 2022.02.09
                    Time: 02:04:56
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 GW MQB High   521 53885388
   Serial number: 15121910520617
   Coding: 030100044F05730000000008000F00010001070000000000000000000000
   Shop #: WSC 00012 790 00037
   GVL: 01443C0100000000400800000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: N/A
   VCID: 70247DAEEAB4324870-8024
   Component: 4-01-09-01-04
No ASAM data for: "EV_GatewNF" (VN46)
3 Faults Found:
131608 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 68
                    Mileage: 20957 km
                    Date: 2022.02.09
                    Time: 02:04:54
131659 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 68
                    Mileage: 20957 km
                    Date: 2022.02.09
                    Time: 02:04:54
8526363 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 9
                    Reset counter: 68
                    Mileage: 20957 km
                    Date: 2022.02.09
                    Time: 02:04:54
Address 44: Steering Assist (J500)       Labels:. 2N0-909-143.clb
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: EV_SteerAssisMNB.rod
   VCID: 45F1D32D5E5D301F98-8010
No ASAM data for: "EV_SteerAssisMNB" (VN46)
Address 52: Door Elect, Pass.
Cannot be reached
Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-ENT2.clb
   Part No SW: 3G0 035 869     HW: 3G0 035 869
   Component: MU-E--ER      715 0740
   Serial number: 09121900011516
   Coding: 066401003C00000041110001000100001F0000C40000010008
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 691D6B41CEE9481BB8-803C
No ASAM data for: "EV_MUEnt4CGen2LGE" (VN46)
1 Fault Found:
1543 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 68
                    Mileage: 20957 km
                    Date: 2022.02.09
                    Time: 02:04:56
8714 - Bulb for Left Fog Lamp - B121F 15 [008] - Open or Short to Plus
919560 - Light Switch - B126A 29 [009] - Signal Implausible
Anyways, the BCM hasn't recognized the Rain-Light-sensor. I would expect to see the RLS as subsystem 1:
Address 09: Cent. Elect. (J519) Labels: None
ROD: EV_BCMA0_204.rod
Rain Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B
Component: RLS 050 0105
Coding: 02B8EE
Drivers Door Control Module:
Subsystem 2 - Part No SW: 7L2 959 405 B HW: 7L2 959 163 B
Coding: 130007
Front Passengers Door Control Module:
Subsystem 3 - Part No SW: 7L2 959 406 B HW: 7L2 959 164 B
Coding: 090007
You do have correct part# for the RLS?
Must assume the LINbus is connected.
Obviously need to have a more careful look into adaptations. Could you please post the adaptation map file (as an attachment).
!!! I note. In the various forums I read more and more about the fact that electronic vehicle parts from the Alixxx sales platform etc. are junk.
It is sensible to only order hardware parts from the Chinese. And here there are also big differences in the housings, connectors, terminals etc. !!!
