Hi all, i have a 2020 t6.1 and I have a tight spot in my steering more noticeable going round right hand corners.
Power steering all works as it should. I thought maybe it was a CV joint or something like that.
Had the van inspected and on a ramp, weight off the front end so wheels jacked ignition on with van not running. Whilst turning the steering full lock either side there’s a tight spot where steering gets stuck and you have to rock it back and forth ever so slightly to get it free moving again. So I’ve been told the rack has failed or failing.
Now a nice shiny new one i have been quoted 2,250 +vat…. Great stuff.
Second hand they are obviously going for alot cheaper, my question is do the part numbers make much of a difference? They use exactly the same part number on the electric motor itself but the rack numbers are different
Part number off mine is 7L2423051E but i see 2022 on they use a rack with part number 7L2423051F
I’m more inclined towards a newer rack but my question is would the 7L2423051F rack work in place of my 7L2423051E rack ?
Any help would be greatly appreciated
Lee
Lee
