T6.1 Traffic Jam Assist
vcds scan
Monday,25,October,2021,01:15:58:52607
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZMH07XXXX License Plate: XXXX
Mileage: 4275 Repair Order:
Gateway Installation List: 3Q0 907 530 AG
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 18 19 22 3C 44 55 5F 65 69 6D 75
A5 BB BC BE BF D6 D7
VIN: WV2ZZZ7HZMH078901 Mileage: 4275km-2656miles
Address 01: Engine (J623-DMZA) Labels: None
Part No SW: 05L 906 023 A HW: 05L 907 309 F
Component: R4 2.0l BTD H80 1161
Revision: N1H80--- CVN: D230C1F9F3218A0EA3C795CF64CF85E9A3C795CF43FB2DAA
Coding: 0025003C0376050800000000000000000000000000000000
Shop #: WSC 00012 790 00152
ASAM Dataset: EV_ECM20BTD01105L906023A 006005
ROD: EV_ECM20BTD01105L906023.rod
VCID: 2615FD3FE86BDACBFDD-8072
VINID: 9E60AAAAA1D8A9D6001C824004AF28E59D
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DV 300 012 A HW: 0GC 927 711 H
Component: GSG DQ500 H06 3702
Revision: 00H06V11 CVN: EC11E75A
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_VN46.rod
VCID: 313F1E63D1A58D7318F-8064
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 7LA 614 517 B HW: 7LA 614 517
Component: ESC_high H01 0800
Serial number: 08505639210204
Coding: 10554752C84EE68D085DE2A413676766382727B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: 3E25355F10FB620B95D-806A
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 7LA 907 040 E HW: 7LA 907 040 E
Component: Climatronic H01 0602
Coding: 0030100008102300010009205040010500000000000B1101B48000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA.rod
VCID: 3D2732531DFD79138C7-8068
Rear A/C control head:
Subsystem 1 - Part No SW: 7LA 907 049 F HW: 7LA 907 049 F
Component: E857 H02 0301
Serial number: 00004066362310211702
Coding: 000000
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 2Q0 937 090 C HW: 2Q0 937 090 C
Component: BCM A0 Std+ H11 0943
Serial number: 00102103902377
ASAM Dataset: EV_BCMA0 206001
ROD: EV_BCMA0_206.rod
VCID: 323D116FD4A3B66B615-8066
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: SBY21M02D03H23M34S38
Coding: 0618EE
Driver door control module:
Subsystem 2 - Part No SW: 7L2 959 405 B HW: 7L2 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000047297719
Coding: 130007
Front passenger door control module:
Subsystem 3 - Part No SW: 7L2 959 406 B HW: 7L2 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000047796439
Coding: 090007
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 2N0 951 173 HW: 2N0 951 173
Component: Sensor, DWA 015 0316
Serial number: 000000000ZY2102019DV
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000049244292
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0073
Serial number: 000150057321034
Coding: 8279167951
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000.rod
VCID: 58E983C7929FBC3BBF1-800C
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 T HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0383
Coding: 302D7F1B4CFFC748949F81BD81508F4018000000008A400000
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
VCID: 45D75AB3752D31D3D47-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 2Q0 959 655 AE HW: 2Q0 959 655 AE
Component: VW22Airbag 016 0506
Revision: --------
Coding: 88CFC00000000000800000CF000C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 00598BA72A8FD4FBA71-8054
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 442 062 101 21
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y55BB008A33384A8
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 442 062 101 21
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y55BB008A33382DA
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 442 0D0 710 20
Component: SideSensor_Dr 30F 1108
Serial number: 351CF11C9338361202BC
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 442 0D0 710 20
Component: SideSensor_Pr 30F 1108
Serial number: 352CF11C13383616638D
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI3
Part No SW: 7LA 920 320 A HW: 7LA 920 320 A
Component: KOMBI 502 5175
Coding: 04AD0088EC8C00080188770F5001000880601E02
ASAM Dataset: EV_DashBoardVDDMQBA0 001044
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 35372A7325CDA153447-8060
Address 18: Aux. Heat (J364) Labels:* None
Part No SW: 5WA 963 271 C HW: 5WA 963 271 C
Component: STH-VW37x 006 0012
Serial number: 000000000000103
Coding: 3143221854121512DCE519
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
ROD: EV_AuxilHeateWOSVW38X_002.rod
VCID: 4CC16F975647C09B0B9-8018
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 521 5423
Serial number: 02022111602461
Coding: 030100344F05730401100258100F00010001070000000000000000000000
Shop #: WSC 00012 790 00160
GVL: 01CC3C00080018C0C0C090008004C80000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 74B1D7776E37F85BB39-8020
Generator:
Component: 5-00-11-00-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 1EA 959 442 A HW: 1EA 959 442 A
Component: MFL H03 0217
Serial number: 17038312062832003862
Coding: AE0D00
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 7E0 915 181 L HW: 7E0 915 181 L
Component: J367-BDMConti H03 1051
Serial number: 77197200002102010831
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 L HW: 0CQ 525 130 C
Component: Haldex4Motion H56 7822
Serial number: HA1-00004.11.20
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4EC5659FA05BF28B65D-801A
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520006659942
Coding: 62954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392F264309D54533A0F-806C
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520006685803
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 1306
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB.rod
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: --------------
Coding: 0C8A02000F210003
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DF4EA361051DF3E8F-8014
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 3G5 035 816 E HW: 3G5 035 816 A
Component: MU-O-ND-EU H56 0782
Serial number: WG8LGM091220000
Coding: 64600000000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_VN46.rod
VCID: 2B030C0BF389E7A3223-807E
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 606 B HW: 5G6 919 606 B
Component: ABT_High-2 H61 9216
Serial number: VWZ6ZJY0320306
Data carrier:
Subsystem 2 - Part No SW: V03 959 809 BM HW: -----------
Component: EU 2020/21 --- 3085
Serial number: --------------------
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 D HW: 5Q0 907 273
Component: RDKBERU30 H06 0010
Serial number: 40000000516523
ASAM Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_VW41.rod
VCID: 36352D7F38CBAA4B4DD-8062
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H0 907 383 HW: 5H0 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005689
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW37.rod
VCID: 6B83CC0B330927A3623-803E
Address 6D: Trunk Elect. (J605) Labels:* None
Part No SW: 7LA 959 107 A HW: 4M0 959 107 C
Component: HDSG-Modul H14 0673
Revision: -------- Serial number: A2-C769-9790-3
Coding: 41A0
ASAM Dataset: EV_DeckLidCONTIVN46T 001017
ROD: EV_DeckLidCONTIVN46T.rod
VCID: 44D147B77E1708DBC39-8010
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 B HW: 5WA 035 284 B
Component: OCUGen3High H20 0035
Serial number: 0000000101VIDN9
Coding: 064620001968982090054601605E2607
ASAM Dataset: EV_OCUGen3High 003005
ROD: EV_OCUGen3High_003_VW27.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 B HW: 2Q0 980 653
Component: MQB MFK 3.0 H13 1202
Serial number: E57829511210200
Coding: 0001080821FAC02890DF2C801030002006238000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW27.rod
VCID: 343117772EB7B85B739-8060
Address BB: Door Rear Drv (J1093) Labels: 7LA-035-593.clb
Part No SW: 7LA 035 593 A HW: 7LA 035 593 A
Component: SLD_Rx-Unit_d H07 0031
Serial number: 190097D1
Coding: 00
ASAM Dataset: EV_ReceiRearDriveSideHuf 002002
ROD: EV_ReceiRearDriveSideHuf.rod
Address BC: Door Rear Pass (J1094) Labels: 7LA-035-593.clb
Component: SLD_Rx-Unit_p H07 0031
Serial number: 190097B8
Coding: 00
ASAM Dataset: EV_ReceiRearPasseSideHuf 002002
Address BE: Slid. Door Rear Left (J926) Labels:| 7LA-959-244.clb
Part No SW: 7LA 959 244 D HW: 7LA 959 244 D
Component: Slidingdoor_d H09 0037
Serial number: 1800760D
Coding: 12
ASAM Dataset: EV_SlideDoorDriveHufT6PA 001010
ROD: EV_SlideDoorDriveHufT6PA_VN46.rod
VCID: 49CF56835935D5B330F-801C
Address BF: Slid. Door Rear Right (J927) Labels:| 7LA-959-244.clb
Component: Slidingdoor_p H09 0037
Serial number: 18007637
Coding: 12
ASAM Dataset: EV_SlideDoorPasseHufT6PA 001010
ROD: EV_SlideDoorPasseHufT6PA_VN46.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 6597BA33D5ED11D3347-8030
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H08 9202
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----------(Elapsed Time: 01:44, VBatt start/end: 12.2V/12.2V)-----------
Hi @LUNGU RAZVAN just wondering if you made any progress with TJA on your T6.1 ?
I haven't yet seen any evidence of any T6.1 or 7LA 909 144 D steering assist being capable of being able to steer (HCA) below 50kph (excluding Park Assist).
The closest I've found is Travel Assist on T6.1 however that still doesn't appear to enable steering below 50kph.
It's likely the Steering Assist would need a firmware hack to enable this (as someone has done on PQ) unless compatible firmware is found which allows steering to 0.
