T6.1 Tyre Pressure Monitoring System Activation (Indirect TPMS)
Thats a good question, the work i have posted is based on vehicles available at that time which i think were all 2021ish models
I see no reason why it wouldnt work on all 6.1 models as long as there were no major changes (and im not aware of any)
This is the details for activating indirect TPMS on any T6.1 vehicle that didnt get it from the factory (huge credit to @mmi for his assistance on this)
Firstly we need to understand what TPMS is, there are two types :
Indirect TPMS - This uses the ABS sensors to measure wheel rotation speed and will give you a dash warning light if any one of the wheels starts to lose pressure (causing that wheel to rotate faster relative to the other wheels) no pressure measurement is taken from the tyres
Direct TPMS - This uses a sensor inside each wheel to directly measure the current tyre pressure and temperature and displays these values inside the vehicle, a drop in pressure in any wheel/s will trigger an alert on the instrument cluster and the infotainment screen
Secondly we need to take backups of the vehicle configuration before we begin, always always take a full scan of the vehicle and save somewhere safe so you have a baseline of settings and things can be reverted if needs be
T6.1s use adaptions channels more than ever as well as basic coding so its important to do a full auto scan AND admaps so you have all the info to fall back on, it does take a little while to complete these scans but it will be a well spent half hour if you run into problems in the future doing this or any other mod !
To activate TPMS we are going to start with module 03 ABS
Enter module 3 and then go into coding/long coding helper
In here we need to change the five values below, its important that all five are changed at the same time, changing them one at a time does not work and will generate an error
Byte 0 Bit 5 - 0
Byte 6 Bit 3 - 0
Byte 8 Bit 2 - 0
Byte 14 Bit 4 - 0
Byte 17 Bit 4 - 1
save the changes and exit
dont worry if faults appear they will sort them selves out when the rest of the programming is done
Now we are going to move on to module 17 instruments
Enter module 17 and then go into coding/long coding helper
Find Byte 4 Bit 0 and turn on (put a tick in the box)
Lastly is module 5F infotainment
Enter module 5F and then go into adaptions
All should show 'not active' so need to be changed to the below values (its quite a long list so use the search box to shortcut to 'rdk' and '0x07' channels)
ENG122227-ENG117541-Car_Function_Adaptions_Gen2-menu_display_rdk = activated
ENG122227-ENG117543-Car_Function_Adaptions_Gen2-menu_display_rdk_over_threshold_high = activated
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07 = activated
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus = Extended data bus
Thats it, everything can be saved and exited, after all changes are made reset any fault codes that are showing
Hey Pauly, do you know if this can be done via OBDeleven?
If you know how to code with it then i assume yes but have never tried/used it
I think the important bit will be the ability to change multiple values at the same time, if you can do that i would say yes
I got around to trying this today as I was updating my wheel size after installing 18” ROC on my van. Wheel size update went fine. Speedo now reads slightly under, which it should be :)
Now onto TPMS. Had issues with setting the Bit values for under 03 ABS.
First off I’m running the latest version of VCDS (updated this morning) and HEX V2.
In the long coding window it shows no Bits when selecting the Byte.
Where the Bits should be there is a message in red that reads “Only Limited Coding Information is available for this Control Module
If you happen to need additional Details please email [email protected]
Coding is normally done using the Factory Tool and Software-Version-Management (SVM)
Changing from Byte 0 to any other clears that message but does not show the Bits until you click on the highlighted Byte in the long code.
So was able to change 6, 8, 14, 17 but not 0.
Looking at how the Byte code is built I was able to work out what I believe is the correct code for Byte 0. It was 30, so I worked out what combo would create 30 and then worked out what the code would be if I set Bit 5 to 0. This gave me a Byte code of 10.
Submitted the updated long code and it was accepted.
Was then able to update all the other bits as per the instructions.
Now the TPMS shows up on my head unit (Composition Colour) but it’s not active. Test on that screen says “Tyre Pressure Loss Indicator currently not available”. If I press the set button I get an error saying it’s not activated.
My only guess is that the long code in 03 ABS must be wrong. Any thought or things I could try?
If you click the lcode2 tab it will give you access to all bytes and boxes, double check your coding
Go back to the start of page 2 of this thread and details are there
Yeah tried that. At first it would open a new window... but it no longer does so. Wondering if the latest version of VCDS is buggy. Might have a look to see if I can downgrade.
Reset it all back to default and then redid each step. Had a few errors. Once cleared I was able to activate all the adaptions.
On resetting the ignition all was working :)
Thanks @Pauly and @mmi for sharing this. 👌🏻
Now I’ve run the battery down and it won’t turn over to start 🤣
Will jump start it after watching F1.
Hi, for those of you who want to use OBD Eleven to activate this function I've done an edit of Pauly's VCDS instructions.
OBD Eleven (This Needs - PRO Subscription)
Indirect TPMS – VW T6.1
To activate TPMS we are going to start with module ‘03 Brakes’
Enter module 3 and then go into ‘Long coding’ then click the icon top right, it’s the one with ones and zeros illustrated on it.
In here you need to change the five values below, it’s important that all five are changed at the same time, changing them one at a time does not work and will generate an error.
To do this click into the area labelled ‘Byte Index’ and type in the corresponding ‘Byte Index Numbers’ below, and click ‘Done’ to go directly to that ‘Byte’:
Note – when a Byte is changed it will be highlighted in green, this is normal. They will stay green until the entire code is saved using the bottom slider. Remember to only do this after all five changes have been made.
Byte Index 0 Remove the tick from the box next to ‘Bit 5’
Byte Index 6 Remove the tick from the box next to ‘Bit 3’
Byte Index 8
Remove the tick from the box next to ‘Bit 2’
Byte Index 14
Remove the tick from the box next to ‘Bit 4’
Byte Index 17
Place a tick in the box next to ‘Bit 4’
Slide the ‘Save slider’ to the right to save the changes and exit.
Now go to module ‘17 Dashboard’
Enter module 17 and then go into ‘Long coding’ and as above click the icon top right, click into the area labelled ‘Byte Index’ again, and type in the corresponding ‘Byte Index Numbers’ below:
Byte Index 4 Place a tick in the box next to ‘Bit 0’
The final module that needs changing is ‘5F Multimedia’
This time enter module 5F and then go into ‘Adaptions’ and NOT Long coding.
All should show 'not active' so need to be changed to the below values (it’s quite a long list so use the search box to shortcut to search for Car Function Adaptions Gen2 and Car Function List BAP Gen2 to speed things up)
Once found tap on ‘Car Function Adaptions Gen2’.
On the next page, search for:
Menu display rdk
In the drop down menu select ‘Activated’
‘Menu display rdk over threshold high’
Once found tap on ‘Car Function List BAP Gen2’.
‘Tire pressure system 0x07’
‘Tire pressure system 0x07 msg bus’
In the drop down menu select ‘Databus Extended’
That's it, after all changes are made reset any fault codes that are showing.
All (cold) tyre pressures should be checked and adjusted as necessary. Then click on the ‘SET’ option on the on screen display, see below for reference.
A huge thank you to all who contribute to this forum, especially @mmi, @Pauly and @dnoermann for all their work on this little gem.
