Hi everyone,
I'm new to the forum and hoping for some advice please. I have recently tried to resolve what I thought to be a classic ABS/ESC rear right wheel speed sensor fault by replacing the sensor with a compatible (I think?) RIDEX Plus component (https://www.autodoc.co.uk/ridex-plus/19290962?search=RIDEX PLUS ABS sensor (412W0153P)).
Replacing the rear right sensor cleared the initial faults but leaves me with 'Incorrect competent installed' and the warning lights still active.... The real time monitoring on VCDS also shows that the rear right wheel speed is still not matched with the other three (wildly different), so something still isn't right. I also note the date is no correct post swapping the sensor, is that a problem?
So my question is where do I go from here please?
Many Thanks
Adam
Address 03: ABS Brakes Labels: 7E0-907-37x-MK100ESC.clb
Control Module Part Number: 7E0 907 379 P HW: 7E0 907 379 M
Component and/or Version: ESC H06 0133
Software Coding: 517E4098256784818A77027CA48821E6790000
Work Shop Code: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001 (VN75)
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB501D17F574D2361-806A
5 Faults Found:
0087 - Rear Right Wheel Speed Sensor
C101D 4A [008] - Incorrect Component(s) Installed
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 32
Reset counter: 35
Mileage: 61516 km
0089 - Rear Right Wheel Speed Sensor
C101D 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 33
Mileage: 61708 km
Date: 2023.04.09
Time: 13:06:38
0091 - Rear Right Wheel Speed Sensor
C101D 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 62813 km
Date: 2023.04.26
Time: 21:54:13
0095 - Rear Right Wheel Speed Sensor
C101D 29 [137] - Signal Implausible
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 250
Mileage: 61708 km
Date: 2023.04.09
Time: 15:47:01
4199 - Rear Right Wheel Speed Sensor
C101D 14 [008] - Open or Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 35
Mileage: 62316 km
Saturday,06,May,2023,18:46:37:35970
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
POST SENSOR REPLACEMENT**
1 Fault Found:
C101D 4A [137] - Incorrect Component(s) Installed
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 3
Mileage: 63240 km
Date: 2075.14.16
Time: 18:41:08
Many Thanks
Adam
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 32
Reset counter: 35
Mileage: 61516 km
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 33
Mileage: 61708 km
Date: 2023.04.09
Time: 13:06:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 62813 km
Date: 2023.04.26
Time: 21:54:13
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 250
Mileage: 61708 km
Date: 2023.04.09
Time: 15:47:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 35
Mileage: 62316 km
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 3
Mileage: 63240 km
Date: 2075.14.16
Time: 18:41:08
