T6 Air Conditioning High Pressure Sensor Fault
mossmotorsport
Hi all, my ODBEleven is reporting an AC high pressure sensor fault (open circuit / short) - fault code B10AE14. I've read that the G65 sensor will probably need replacing, does anyone know where this is located? I think I've located it in the picture below, but it's impossible to get a spanner around it to remove? ThanksIMG_7641.PNG
Hi all, my ODBEleven is reporting an AC high pressure sensor fault (open circuit / short) - fault code B10AE14. I've read that the G65 sensor will probably need replacing, does anyone know where this is located? I think I've located it in the picture below, but it's impossible to get a spanner around it to remove? ThanksView attachment 254945
Hi, I have same problem aircon blowing lukewarm instead of ice cold. Did you get to the bottom of the fault
