chris11vans
Good afternoon ladies and gents , i am new hear but would really like advice .
CXBG 2018 transporter ( camshaft module version) 80k
One of the company vans i look after was poorly , the cambelt was split nearly in half and on just cranking over not driving ,took out the (in words) the pin on the camshaft pully allowing it to spin freely when i checked the timing releasing the 18mm bolt
So basically the van suffered the following findings
Camshaft sprocket scrap as locating pin snapped off , new pulley purchased
8 out of 16 rockers smashed , 16 new purchased
replaced all injector seals
gaskets etc
from what i can see no1 exhaust cam lobe only nearest the belt just 1st has spun literally 2mm
pistons ok via camera inspection valves all seem same height and open and close nicely.
put it all back together as i hoped and preyed that as the lobe was so slightly out i may get away with it. (
Rebuilt everything, turns over by crank lovely and smooth , all locking pins fit .
NOW ...
do i need to purchase a new camshaft module between £600- £1200 unless anybody can help or knows a secret place to buy
Its cranks but will not start,,
i have the following info
fuel pump has no metallic bits inside
on crank
camshaft phase 0.7 deg
fuel pressure on cranking 30000 kpa
crank speed 210 -250
camshaft speed as above
main injection start 0.5 deg
main inj duration of activation between 1700- 2240 us
starter control engine active
maf 14 %
engine status engine start
these are all average reading from my obd eleven scan
i can send screen shots etc if it helps i just need some advice as its frying my brain
occasionally it will fire and run for 2-3 seconds and stall
i have disconnected cam sensor no change
haven't tried fluid start yet
i really appreciate any advice
thank you all
gaskets etc
NOW ...
on crank
maf 14 %
thank you all
