T6 - Front Upgrade - In for a penny ??
Just wanted to say thanks again @Pauly , I’m continuing to read through the various related threads/posts on this subject and the following came up?
I assume this is not a necessity, more a nice to have ? Is that true ?
Also, am I right in saying that the new 8K module that’ll come with the front PDC kit from car systems eu, will be pre-configured so will be seen and work, straight out the box once it’s all installed? (No VCDS etc. required for the retrofitting front sensors?)
Sorry to highjack this thread, I am looking at fitting front PDC, the controller I have is 7E0919475T - Parklife 4k is this compatible with 7E0919475S / 7E0919475AA quoted for front and rear PDC? I.E do I need to change (J446)
Also is it possible to retrofit the front ACC? sensor as this 2017 TDI150 DSG Highline doesn't have it fitted
Trello
4k means 4 sensors ie rear only so you will need to change it for 8k module which is 8 sensors ie front and rear
Hi @Trello , it sounds like you’re attempting a similar project to me, (although I need to finish my cab upgrade first, before I start anything else, especially taking the front off :-) )
Would love to hear how your retrofit goes, and the exact parts you buy.
Are you doing the fog lights too, or do you have them in already ?
Hi, I already have the fog lights.
Likely -
Fit DRL's with the Parking sensors (gloss)
Change the fog light inserts to gloss with the sensor holes
