T6 T32 204 front brake hoses
All,
Hope someone can help. I want to change the flexible hoses on my front calipers but there seems to be two variation 550mm and 600mm. Which one is needed or can someone post a part number.
I want to change them as the brakes are binding on one side and after stripping and lubricating the slide pins it is better but still binding. Thought was maybe the flexible hose is damaged and not letting pressure back.
Any help most appreciated
More likely to be the caliper piston sticking........better off just replacing the caliper.
Seal and piston kits cost peanuts if you are happy to overhaul the calipers. I’ve not sourced T6 caliper parts but Autodoc tend to have a good choice.
Just make sure that it’s the correct kits for the caliper.
