Being a T6 geek and spending my Sunday afternoon trawling through T6 TPI`s and Service info i thought i would share this with you.
stop/start is a very complex system even though you would assume its simple.
An interesting read IMO and details the stop/start requirements and issues/non-fault scenarios.
T6 TPI - start-stop system fails intermittently, engine does not switch off or on -
11/14/2018 Technical product information 2039908/1
Technical product information:
Service info: start-stop system fails intermittently, engine does not switch off or on Transaction No.: 2039908/1
Release date: 27-Feb-2015
Customer statement / workshop findings:
The start-stop system fails intermittently. The engine is not automatically switched off or on.
Technical background:
This TPI only applies to vehicles with the with start-stop system.
The start-stop system allows automatic engine stops and starts.
Because of different factors the engine may not automatically be switched off although the driver expects it.
It is also possible that the engine starts automatically although the driver does not expect it.
For the start-stop system to work there must be no incorrect function and no event entry in the control unit that could affect its operation.
The engine is automatically switched off if the following conditions apply:
• The minimum engine temperature has been reached. Unless this is the case, the system does not switch off
the engine to avoid interrupting the warm-up and to ensure that the heating is available as quickly as
possible.
• The vehicle has exceeded 3 km/h and driven a few metres before coming to a complete standstill.
• On automatic vehicles more than 10 km/h must be reached.
• The charge level of the battery must be sufficient so that the engine can be restarted. To ensure this the
battery manager constantly monitors the charge level of the battery.
• The defrost function of the windscreen is deactivated and the outside temperature is over 3ºC.
• The driver must wear a seat belt.
• A gear must not be selected.
• The clutch must not be pressed.
• The driver door and the bonnet must be closed.
• The engine speed must be below 1,200 rpm.
• The diesel particulate filter (DPF) of the engine must not be in the regeneration process.
• The difference between target and actual interior temperature must not be more than 12ºC.
• The road incline must be under 10º.
• The steering wheel must not be more than 270º (3/4) turned, as the vehicle comes to a standstill.
• On automatic vehicles the brake pedal must be pressed and held as long as the start-stop function is to be
active.
In the following situations the engine is not automatically switched off:
• The vehicle is electrically connected with a trailer.
• The system was manually deactivated with the button on the centre console.
• The clutch is being pressed.
• A gear is selected.
• The brake pedal is not pressed sufficient hard and held.
• The parking aid is switched on.
• The interior temperature selected on the air conditioning system has not yet been reached.
• The charge level of the battery is too low.
• The windscreen is being defrosted.
• The steering wheel is turned more than 270°.
• The vehicle is inclined too much.
• The system remains switched off, if after a replacement the battery has not been adapted with the Guided
Functions or if after such an adaptation the system is in the process of calculating the charging curve. This
process takes about 10 start cycles and varies depending on vehicle and equipment.
In the following situations the engine starts automatically without driver involvement (without pressing the clutch pedal):
• The vehicle moves with switched-off engine and reaches a speed of more than 3 km/h, for example because
of a slope.
• On an automatic vehicle the selector lever position "R" is inserted.
• The coolant temperature drops or rises too much.
• The vacuum in the brake servo has dropped leading to reduced braking assistance.
• The interior temperature differs from value selected in the air conditioning system.
• The outside temperature is below 3ºC.
• The charge level of the battery is below a certain level.
• Many electric electrical consumers are switched on.
Requirements for the engine to be started deliberately after being turned off by the start-stop system:
• The clutch pedal must be pressed.
• On automatic vehicles the brake pedal must be released.
• The bonnet must not be open.
• When pressing the clutch pedal the driver door must be closed.
• The seat belt of the driver must be in the belt buckle and must not be released.
Further information about the start-stop system is included in the owner's manual.
Production change
This TPI applies to vehicles equipped with the-start stop system.
Measure
If a customer complaint is confirmed, proceed as follows:
For checking and effectively diagnosing the start-stop system use the Guided Fault Finding.
The start-stop system is complex and the number of the conditions affecting it is high.
Our analysis of the replaced components shows that a high percentage of damaged parts submitted under
warranty are correct and were replaced unnecessarily.
For the technical support and to avoid unnecessary repairs and repeat repairs we recommend to make a
technical repair enquiry if the check of the system with the Guided Fault Finding and this TPI finds no cause.
Always attach the historic and current event entries to the technical enquiries.
Please do not replace parts based on assumptions following the diagnosis. Please inform the customers about
the background and possibilities of the start-stop system.
Warranty accounting instructions
Customer information
Please explain the factors outlined under Technical background. The customer required needs to understand
that the start-stop system may not necessarily malfunction (depending on the result of the Guided Fault Finding).
why cant you disable perm? . . . . . now you know!
Customer statement:
The customer wishes a permanent deactivation of the start-stop system.
Workshop findings:
A permanent deactivation of the start-stop system is not possible.
The start-stop system is an integral part of the registration and must not be permanently deactivated, as it is used for the consumption figures and especially the CO2 emissions for the registration. A permanent deactivation of the system would invalidate the operating permit of the vehicle.
Measure
- Customer information
Explain the background to the customer. It is only possible to deactivate the start-stop system with its button till the next terminal 15 change
possible.
active.
of a slope.
Production change
Measure
Customer statement:
Workshop findings:
Measure
