T6 wheel bearing
NickWoods
Does anyone know if a bearing puller intended for a T5 will work to change a rear bearing on my T6?
There are so many pullers listed on eBay for a T5 but I’m struggling to find one for a 2018 T6, is the hub different on the two vans
I`m sure the T5 and T6 wheel bearings are identical so puller should be the same. The fronts are also the same as the rears.
yep, specifically bought a puller a few months back, it was labeled as a T5 tool, but did the job for my T6 rear, you wouldn't want to do it without the tool....also double confirm, the wheel bearings i bought were suitable for both front and rear.
Are the cheap pullers for £50 ish worth it?
I've only got one to do at the moment but hoping it would last long enough to do all 4 as the years go by.
If they're crap and break on the 1st use I won't bother.
