perranpedro
Does anyone know if it’s conceivable that retrofitting a kenwood dab stereo fitted to my 2015 sportline can result in my tail light cluster now not illuminating ? All bulbs are intact and work on the respective (brake) pedals and reverse setting when actioned individually. If I disconnect and reconnect the battery (which I did to check the connections) the tail light cluster illuminated correctly until I drove away then immediately went off completely and back to working per individual bulb? Someone has mentioned that it could be a voltage issue and due to the sportline wiring loom ? I have approached the garage that fitted and they say the issue is not connected despite it starting within 24hrs of the fitting so not being familiar with vehicle electrics I’m really confused and would appreciate any ideas thanks
