Good - you're in the right place then.Also I was told last night the van is a T6 NOT a T5.1
Did you carry out any work prior to them not working?
Thanks so much Deaky, I would never have thought only one fog light but now you mention the wiring your right, I would have spent days looking for that. I will take a look for those other 2 wire for the ABS speed sensor is the "slippery road" looking icon the same as the speed sensor? Also who are Carista?It's normal for some vans to only have one fog light, even though the bulb might be present in the cluster that's not working. The photo you posted of your light cluster wiring further up the thread shows no wire present in pin 1 so you only have one fog light on your van.
An ABS speed sensor could be causing the warning lights your seeing. The rear sensors pass through the brown connector under the passenger seat, I'm not 100% but think they follow the same route to the back as the lights.
Rear Left speed sensor is a black wire and a green wire
Rear Right speed sensor is a brown wire and black wire
It might be worth getting Carista to scan your van to find out exactly what the issue is.
It’s a strange one all lights worked after the pop top fitted and picked up. Week or so later I fitted 50mm spot lights that I had to drill out. But the damaged wires are between the 2 holes I drilled, so I’m thinking it must have been a screws from the pop top fitting.¯\_(ツ)_/¯How did the wires behind the lights get damaged? have you just had a pop top fitted?
Just checking I haven't made a schoolboy error in bridging these wires along the pop top to the rear of the van. 1 or 2 of these wire were very thin and I never had this very thin wire so have used thicker lighting wire would this be too thick and disturb the current passing through it?
At least two of those wires in the photo you’ve sent match what I posted ten posts or so above - they go to the rear light cluster.Grey/black
White/black
Grey/white
Green/black
Yellow/black
Red/gray
Both ABS (Anti-lock brake system) and ESP (Electronic stability program) rely on data from the rotational speed of each wheel, hence if one or more of the speed sensors is not working an error will occur in both systems.Thanks so much Deaky, I would never have thought only one fog light but now you mention the wiring your right, I would have spent days looking for that. I will take a look for those other 2 wire for the ABS speed sensor is the "slippery road" looking icon the same as the speed sensor? Also who are Carista?
Cheers again Neil
Yes it looks like only 1 fog light who'd have thought. Everything there in the cluster of lights to work but no wire. Might put power to the other fog light at a later date. Now for the 2 warning lights on the dashIt's normal for some vans to only have one fog light, even though the bulb might be present in the cluster that's not working. The photo you posted of your light cluster wiring further up the thread shows no wire present in pin 1 so you only have one fog light on your van.
