Tailgate, open from inside?
Stupid question #1 of 1:
Is there a kit or modification that can be fitted/done so one can unlock and open a T6 tailgate from inside?
Would prefer to be able to do it from 'above bed level'.
Its pretty easy to setup a switch/button to open the tailgate from the inside but a bit more tricky to unlock it
For an open button you just need any type of momentary switch (ie spring loaded) and connect it across the two wires that go to the external tailgate handle, there are loads of threads and posts covering this, if you are not sure have a search around and more details and pictures etc can be found
For a switch to lock/unlock - have a look here:
For a switch to open, e.g.:
Is it possible to install an internal switch to open an electric tailgate on a T6 Kombi?
