Tambour Door!
Parky007
Hi all, has anyone had any issues with vertical Tambour doors? I’ve got an Evo Motion kitchen & the tambour door which holds the water tank & gas bottle is stuck!
Has anyone got any ideas as to how I can fix it without taking the unit apart?
It’s probably a small item that‘s been dragged in behind the roller.
I think I may have to … the last alternative will be to break it or cut a hole in the shelf above it so I can put my hand down and through ¯\_(ツ)_/¯
Tape a short piece of hose pipe to a vacuum cleaner nozzle and feed it in behind the roller with the vacuum cleaner running. Move the hose about and it should suck onto the item that’s jamming the roller.
