Thanks mateThanks Dave!Tyres are 255/45/18 Goodyear Eagle F1’s
Message me. But if your after a load rated tyre then forget it.@Jayjmac I like that stretch. what size tyres are these on what size wheels??
I've never lost any on my range rovers or my amaroks. I have 3 sets of black and 3 sets of black with the silver vw sign because I thought I’d lose loads! Never lost oneHas anybody had problems with there centre caps coming off? I,ve lost one already and I,ve just put the bloody wheels on
Gonna silicone glue a bolt head, that should work, crazy, you would think they would stay on no bother, the wheels are jbl banded pepperpotsAre those the TWS ones? I had a set of them and lost all my caps at some point. The Amaroks steels have been fine for 3 months.
You lucky man, seriously, first day , I must be just bloody unlucky mateI've never lost any on my range rovers or my amaroks. I have 3 sets of black and 3 sets of black with the silver vw sign because I thought I’d lose loads! Never lost one![]()
Yep it was only the JBW wheels that mine were lost from as well. Must just be that the centre caps dont quite get a good clip.Gonna silicone glue a bolt head, that should work, crazy, you would think they would stay on no bother, the wheels are jbl banded pepperpots
Definitely mate, going to pop a little bit of silicone glue on a couple of bolt heads so it doesn’t happen againYep it was only the JBW wheels that mine were lost from as well. Must just be that the centre caps dont quite get a good clip.
They’ve stayed put on my JBW’s fine, even with OEM studs on the front and Watfield studs on the rears.Has anybody had problems with there centre caps coming off? I,ve lost one already and I,ve just put the bloody wheels on
They appear to be
You just need some regular VW steel wheel centre caps.... and the best man for that is @Radford1071sHi folks - with regards to centre caps, it turns out I’ve just purchased a set of JBW wheels and I need centre caps... the centre bore diameter is measured at 72.6mm. Has anyone purchased Vw caps of this size, and if so, where from? Cheers!
The centre bore is for fitment onto the the hub of the van
@DaveBowden74 above has just fitted some JBW steels
