How do you plan to use the vehicle?Thanks I just don't know where to start
I know that feeling.Thanks I just don't know where to start
I think you are getting set for some blood good adventuresKombi 204 manual 4 motion in mojave 6 seats dual passenger and 2 plus 1 in rear
I think everybody on this forum will have a different option, that is a really good thing imo.what should I aim to do first. Does dropping it affect warranty ?
Depends how you drop it. apparently B14 gives lots more other than a drop (according to all the posts regarding them). Personally I think a -20/-30mm is enough, but some go down -70mm with the b14; I think you may loose some of the vans utility if you do that. Big advantage with the b14 is you can change your mind , and tweek the heights every week if you wishWhat benefits other than aesthetically does dropping it give
VW are very good regarding mods in most peoples experience, it is a big part of VW ownership for lots of people.That's a good reason thanks. Does dropping it affect warranty?
Yep Highline, good choiceTrim spec ? Is that high line?
