Team Sportline.
Yes I like them, to be fair I don’t really have nothing to compare them to as old van was just lowered on springs with factory suspension.
It is a nice ride they got longer drop links and heavy duty rubber mounts
Looks ace indeed!
Mines still Standard. Would like to know the same. What wheels and what suspension you running??
I’ve been looking at the Bilstein Comforts.
The suspension is H&R from Steve at CRS Performance and the van is currently lowered 65mm, the wheels are Leighton LV3s,
I see all but one BE and most of the new sportlines are gone from AT, does this mean we now have the super exclusive vans now,
all jokes aside surely these vans will hold money well with no more new available
Still a few sportlines available I’ve seen.
On another note, did you get a spare wheel with yours??
Mine came with a can of foam, tyre inflator but as I had a 17” tyre I got a 17” steel of someone off the forum then @Pauly helped out with a tyre carrier and got me the other bits needed. I just added the required block of foam!
If you need part numbers I’m sure @Pauly can help. :thumbsup:
They haven’t made that many in total
Just noticed mine our starting to come loose
Both my side indicator badges coming loose, one now snapped off before had change to apply some contact adhesive as the double sided tape they used in factory is not good. Trouble is cannot find any supplier of a replacement "Sportline" indicator badge. anyone have any thoughts apart from VW themselves? Van is a 2022 T6.1 Kombi Sportline Black Edition.
Well known problem. Both mine are loose. Waiting for it to get warmer then take them off. On the back fill the criss pattern with epoxy resin. Sand them flat and restick with double sided 3m tape.
It don’t help you out of course but these I’ve heard through the grapevine are on back order. Should be under warranty though??
Mine were done under warranty and they have been solid for over a year now
Mine same issue, new ones fitted under warranty recently. So annoying!.
