Yes really pleased with it and it fitted perfectly, I believe they saved all the measurements so are able to CNC cut as many as required for other members.
Hi All,
Based on the dimensions of the original picture (I worked from the centreline to make it symetrical) I attach a AutoCAD dwg and PDF file of this which can be printed 1:1 scale on A1 or if you know someone with a CNC machine can cut it out using the dwg file. I hope it's useful for someone?
Hi All,
@Evie T. MDF or hard board (which I used on mine) is very easy to cut with either a hand or jig saw. As I mentioned in an earlier post, I made a template from cardboard first (cut with scissors from the drawing dimensions) and only put a saw to the hardboard once I had the shape right,
Thanks. I don't have a hand or jigsaw but already have the template which was sent with the bracket when i bought it. I have had some quotes for both MDF and Polycarbonate cut to the template... Ranging from £30 - £72
