Thule 9403 electrics
Parky007
I’ve just acquired a Thule 3 bike rack to fit on my T6 towbar. However the electrics don’t seem to be working - no lights or brake lights coming on. The outer cap is damaged so doesn’t sit in the rows at electric adapter comfortably. Could anyone help please? Many thanks
It does look as though the connector is damaged. New ones are readily available. You could also invest in one of these. It tests both the van side of the towing set up and the trailer side.
Thank you for your help. Do you know where I can get a connector and will it involve buying the lead/wire?
You can buy the connector on its own from Halfords but will need to take off the old part as the nut that tightens the waterproof seal appears to be missing. It’s a simple job though
