Tiguan Seats Fitted
I used the Kufatec loom and you’ll also need an original control panel and relay. It was a pain to figure out which wires I needed on the Tiguan side of the plug but I got there in the end. Give me a shout if you ever get round to it and hopefully I’ll be able to help
Hi, sorry if this has been covered before, I have been looking at fitting VW Tiguan seats inside my T6, can any body advise me of the best adapter plates available, THQ? Do the plates fit straight off the shelf or need adjustments / modifications etc, what are the costs of plates as I’ve only seen the THQ plates. THQ plates don’t mention if Tiguan seats fit there plates.
Many thanks.
Many thanks.
I used the THQ plates in my 6.1 for Tiguan seats. Should be a straight fit as they are made for any VW seat I believe. I had to open the holes a little that’s it. You can make your own, plenty of vids on YT.
Many thanks.
I used the plates from THQ and Tiguan seats went in with no problems.
Hope this helps.
Thanks for the swift replies, can I ask, after you fitted the Tiguan seats what did you do to tidy up the lower sides around the metal frame and runners, I know THQ were going to make some plastic covers?
