Tow Bar
Someone gave some very good advice on here.
If you have a removable hook which you leave on, but then want to tow, remove and refit the hook before you tow.
They have been known to fail, apparently, having been left attached for long periods.
I did not know that! What exactly fails, do you know? I might make some enquiries about the Receiver Hitch or get oilin an greasin. ;)
No idea on the actual failure.
I only use mine for the Towbox, and remove it after every trip (I need to reverse right up to the wall on my drive - every inch counts!).
I only recall a discussion on here a number of years ago, where a member discussed a failure of a removeable tow hook, which had been left in place for an extended period, unused, but then failed when towing.
It struck me as very good advice.
I’ve got the Westfallia detachable towbar.
As others have said get the proper 13 pin electrics and make sure it’s coded into the van.
Fitted mine myself so can’t help with recommendations.
Firstly, thank for all of your input. Decided to go for Tow Trust detachable with 13 pin electrics which i’m having fitted by a local firm (to me Oxford) next Thursday. So, will report back then………….now for the bike rack………
Oxfordshire Tow Bars (Colin(based near Abingdon) fitted the tow bar today great service and product and a reasonable price.
