Towbar question please
T6 dork
Engineer
do you have a factory fit or retro fit towbar with a factory rear camera anyone ?
what happens to the rear parking sensors and camera when a trailer is plugged in ?
I have camera and retro fitted OEM detachable towbar (westfalia)
When you connect a trailer and go into reverse it shows a pic of a trailer on the screen and the reverse sensors are disabled and foglight is moved to trailer
right...
i have fitted a westfalia detachable towbar and dedicated wiring kit from PF Jones
all works ok but the parking sensors and camera are still on
Have you coded it in ??
Need to add module 69 to the system
i wasn't doing the coding, so i will ring my man see what he did, many thanks..
ok so he says he did add that, so i dont know now :(
Sorted .. pic of car and trailer on screen now and sensors deactivated when plugged in..
Wrong code was entered..
total cost £400 all in..
sorted :thumbsup: will be working properly now, unplugging the trailer when locked will set the alarm off
