Towing a caravan and carrying bikes.
If it's a big van (mines 1900KGs) and you load up a lot in the T6 then I'd go for 150 rather than 102. Like many I take way more stuff than is needed camping.
I have DSG and drive it manually when towing as it's rare for me to get into 6th let alone 7th gear. At 56mph it's usually happier in 5th. I suspect a 102 wouldn't get out of 4th except downhill.
Can you tell me how you drive it manually? I have a DSG and tow a small van. I've never driven it manually but it would have been useful to be in a lower gear than the engine thinks as I can see the road!!
You can use the gear lever by moving it to the right and then pushing forward/back. Or if you have paddle shifts on your steering wheel then you can change gear with them like I do.
I never used manual mode. Sport was sufficient when towing if it got steep or twisty as it holds onto the lower gears for longer.
D is eco orientated, so will put you in a higher gear as soon as possible. S holds onto the lower gears for longer, keeping the engine revs where the most torque is produced for more responsive acceleration, or pulling up hill.
Don't overthink it. You won't break anything. Just try it and see what works for you.
Cheers for that
We tow a small trailer and fitted a Thule caravan A frame mounted bike rack…..we had to choose the short version at 49 cm so to allow better turning….
It’s alternative option :)
fits 2 x e-bike
We have the same rack on our caravan, better to put them on the front of the caravan than on the back due to the weight distribution.
I cant answer on an additional tailgate rack, but on the front of the caravan works perfect.
For the first time, I had to use the tailgate rack when towing the caravan. No issues with manoeuvring unless it is a very tight turn (where you practically have to jack-knife!)
I was disappointed that our new caravan couldn’t take a bike rack as our previous caravans did, but I’m happier using the tailgate rack
