Depends on the length of your draw bar - I think you may struggle. Here is a photo of my OEM rack, loaded with 3 bikes, with my boat trailer hitched up to give you an idea:-
Phil, from the lowest point of the rack is currently 110cm to the ground at the front of the rack and 122cm at the rear - once fully loaded for camping plus circa 50kg trailer nose weight this will reduce by a few cm - the height from the top of my towball, which sits just above the bumper step, is 72cm - this will not change regardless of loading/suspension height.Hi Dave,
We have a folding camper which is pretty low behind us. Would you be able to measure the distance from the bottom of your rack to the ground if you have chance so I can see if it would clear it. Also is yours lowered? My T6 is apparently factory lowered (only just got it), so not sure what the difference to standard is.
Much appreciated
Phill
From the tailgate steel face to outermost point is 830mmJust to bring up an old thread, can anyone advise on how far the version 2 rack sticks out from the tailgate when loaded and at what height please
Think that’s a bit to close for towing, it’s only 300mm from the caravanFrom the tailgate steel face to outermost point is 830mm
From tarmac to lowest point is 1070mm closest to tailgate & 1170mm furthest from tailgate. This must mean the bike rack base is not 90 degree to tailgate
Van is on level tarmac
T6 is on 40mm lowering springs
Hi @Eli ... just had a quick nose...Coachman don’t do any cycle carriers for their vans ...the other suggestion is put the bikes in the vanThink that’s a bit to close for towing, it’s only 300mm from the caravan
I was thinking about padded bike bags AndreHi @Eli ... just had a quick nose...Coachman don’t do any cycle carriers for their vans ...the other suggestion is put the bikes in the van
Yes ..saw them ...look good and will keep the van nice and cleanI was thinking about padded bike bags Andre
