Hi everyone,I
I recently bought a sexy looking T6.1 which I intend to convert to a day van. Koni suspension had been fitted along with a new set of 19" alloys. Whilst I spotted tyre warning light was on the dash, I wasn't overly concerned as I thought it would simply be a case of check tyre pressures and reset.
When I got the van home and went into the info system, the TPMS was unavailable. After reading great info/advice on this forum, I identified the problem...the van had direct TPMS but no sensors fitted to the alloys.
I got 4x sensors pre-programmed for a T6.1 from UK parts direct and had them fitted. TPMS now working and showing the correct pressure for each tyre. Chose a tyre size that allows the new wheels to run within acceptable pressure (all 4x tyres over the set pressures). So no tyre pressure issues on the info centre. However the low pressure warning light is still illuminated on the dash and my MOT is about to expire. Tried every trick to try and get it to turn off but still on. Do I need someone with VCDS to simply clear the fault.
I've been told it could be a sensor fault, but all give a signal and the info centre displays all four tyre pressures correctly, so can't believe it's that.
Any suggestions would be gratefully received
