They use a H7 setupBut that's the same as the h4 standard surely?
And they're not bright enough to see anyway.
If the H7 bulb isn't seated correctly the light pattern is wrong and you don't get the proper dipped beam cut off - good chance you were dazzling the oncoming drivers which is why they were flashing.Everyone was flashing me, as they thought I was driving with just the DRL’s on as the light out out is so dim through that lens.
I spoke to VW UK over these lights and vehicle warranty, they just suggested to speak to local VW garage warranty manager. I explained what I wanted to do and he said it would be a common sense approach and if the lights are just plug n play then they should not affect warranty to the electrics etc. The lights would obviously not be covered as aftermarket.
Got a link to the ones you used please?Led bulbs in the projector is a must! Light quality then is very very good.
I would get that in writing if I were you. Even then, think twice about it. I've been burned before by mods invalidating warranty, even when completely irrelevant to the fault.
Several months in with mine now (after waiting for my warranty to expire before fitting). Still love them, especially the sequential indicator flash when I unlock the van. I may have watched a bit too much Knightrider as a kid.....
Had my van into VW as it went into limp
home mode. Needed a regen.
Mentioned the headlamp units to the service guy. They had no problem with them. And stated it would not invalidate my VW warranty in anyway. But as someone else has already said. Headlamps obviously not part of warranty if non OEM.
I went for these LED bulbs:
H1 Twenty20 Compact LED Headlight lamp
H7 Twenty20 Compact LED Headlight lamp
Spoke to a guy at Besfest who had the units from Travelin-lite. He said his had come with Philips and Osram versions. but they worked out at twice the cost of almost £100 pair vs my £50 pair.
The main beam lamp did not locate normally into the lugs. So I had to manually put in the diagonal position myself as the mean was incorrect.
I think the next thing is to
pay do a headlight alignment to
make sure the beam pattern is set up correctly.
But at the moment vast improvement. And driving with levelling control in lowest position to try and avoid blinding oncoming cars.
