They said they're happy to do a group deal for the forum but think they might have been banned? Not sure why..
This has been covered in 'rubbish headlight' type threads previously - I did try a couple of expensive 'reflector' HID kits (not ebay specials) in my H4 units. First kit was 55W and even after turning the bulb warning light off with VCDS, the vehicle would sometimes turn one of the lights off or it would start flashing slowly. Second set was 35W which still caused a bulb warning from time to time. Light output was brighter than stock but it still gave out that horrible puddle of light with the added extra of lots of light scatter above where the cut off should be. On these the light source is moved within a shroud to swap from dipped to main - you could have both lights aligned on dipped however on main they both pointed at different heights. I got the supplier to send a few bulbs for me to try out and every single bulb had a different delta between dipped and main light direction. The other issue is you need to butcher the bulb cover to fit the dipped/main solenoid into the unit. I'm running THQ with halogens now and am more than happy with them.On the other hand though we also need some hero to try fitting an H4 Hid retro fit lamp kit to their shonky VW H4 headlights so we can see if that's a viable option too
Fitted my V2 recently. Gorgeous to look at. Indicator looks great. DRL looks so good. BUT.... in the dark? absolute wank. £520 for pretty much a more handsome H4 headlight.
If I had the time and it wasn't a bumper off job i'd be sending them back.
Just the dipped at present never crossed my mind to put them in the full beam. Why you ask?.
And they've the nerve to say "you have probably fitted the bulbs incorrectly...."
Yeah, course I have.
V1sAre your THQ lights the V1’s or V2’s @Mooncat?
