Daryl_88
Any idea if this feature been removed by chance? Need to code lamp monitor out for new led tail lights as it’s messing with my reverse cam.Andy have you tried the new Carista update has a "lamp out" monitor tick box?
(2018 t6)
You need to turn off PWM not bulb monitoring. Not sure it can be done with CaristaAny idea if this feature been removed by chance? Need to code lamp monitor out for new led tail lights as it’s messing with my reverse cam.
(2018 t6)
Cheers mate, I ran through all the menus on Carista with no avail, so I’m assuming it’s a vcds jobYou need to turn off PWM not bulb monitoring. Not sure it can be done with Carista
What age are your vans?
I had a 68 plate for a few weeks and did many VCDS tweeks. An out of the blue unbelievable deal saw me changing it for a 19 plate one. My VCDS wouldn't do a thing, so I spoke to Gendan who confirmed that MY19 vans had changed in terms of electronics. So I needed to get the new VCDS cable.
When it came to headlights, I went for HIDs in my THQ dipped beam. I tried all sorts until speaking with the company I bought the final set from. They also told me that the MY19 vans were extremely sensitive and even with bulb monitoring turned off, most CAN BUS kits would still trigger the warning light. And sure enough, the kit they recommended worked perfectly.
As far as I know they only do the crystal ones now as there were issues with the indicator not being visible enough in bright light with the white onesSome great info in here - I’m just about to go for a set of THQ V3 in black. I’m unsure about white or crystal diffuser - is there much difference in the 2? Does the white drl diffuser minimise the individual leds you can see with the crystal? And if so is it that noticeable. Any pics or comparisons would be great!
It depends what's more important to you, solid DRLs, or DRLs and Indicators that can be seen by others in daylight?Some great info in here - I’m just about to go for a set of THQ V3 in black. I’m unsure about white or crystal diffuser - is there much difference in the 2? Does the white drl diffuser minimise the individual leds you can see with the crystal? And if so is it that noticeable. Any pics or comparisons would be great!
Well that’s what I thought but they appear to have either option on their website currentlyAs far as I know they only do the crystal ones now as there were issues with the indicator not being visible enough in bright light with the white ones
These look awesome. Can’t find them available anywhere yet though?@Tom-E86 In case you’re still undecided - There is another option, as mentioned by @dubber36
More expensive than the V2 & V3 but ticks all boxes
They definitely fit the brief mate. They’re available to THQ’s authorised dealers on a supply & fit basis only at the moment, I believe. Will then make it onto the website for general sale at a later date, but I don’t know when that’ll be…if you’ve got someone local who’s able to do it, I’d defo recommend having a chat with themThese look awesome. Can’t find them available anywhere yet though?
As stated above, they are only currently available through the dealer network. I've done several sets at the cave now and the feedback has been incredible. They are several levels above the older V3 etc. Easily comparable to the genuine VW LED units.These look awesome. Can’t find them available anywhere yet though?
They do look like the complete package. Unfortunately you’re about 4 hours from me I think as I’m in Essex. Would be interested in prices though.As stated above, they are only currently available through the dealer network. I've done several sets at the cave now and the feedback has been incredible. They are several levels above the older V3 etc. Easily comparable to the genuine VW LED units.
I'll DM you with my pricing, but there would no doubt be someone closer to you who can help.They do look like the complete package. Unfortunately you’re about 4 hours from me I think as I’m in Essex. Would be interested in prices though.
Keen to see the pricing on these too. I’m Bristol based so not a million miles from you.I'll DM you with my pricing, but there would no doubt be someone closer to you who can help.
Have you managed to establish the way to code them so the warning light doesn’t come up on the dash?I'll DM you with my pricing, but there would no doubt be someone closer to you who can help.
Not via coding no, but disabling the headlight startup sequence has stopped the dash warning light on the few vans that have shown the issue.Have you managed to establish the way to code them so the warning light doesn’t come up on the dash?
