AdamHughes
Hello there.
I seem to have an issue with my leisure battery not holding charge and speaking to the form I purchased the van from and reading up fully (which I should have done before), I believe I may have damaged by leisure battery by allowing it to get completely discharged a number of times.
I’ve been told to remove the leisure battery and trickle charge it (should take a few days) to see if the battery is okay.
Am I right in saying that I have to remove the drivers seat in orders to get the battery out ?
Also I’ve read that it is a good idea to trickle charge your leisure battery every few months anyway (which I have never done before).
If this is the case is it a good idea to install a trickle charger in the camper to enable the trickle charge without the need to remove the battery ?
