might be hard to drill out if you can't get that easy out first maybe try and tap the screw around with hammer and small chiselGeez...
Looks like you will need to drill out the core of the bolt.
Then try a easyout, reverse tap to get it out.
I'd be using a impact screwdriver... To try and shock it out.
Nice set that.....You're going to struggle to drill out the embedded tip of the broken extractor.
I would get a small, sharp cold chisel, and carefully try and knock the bolt head in an anti clockwise direction.
Once you get the chisel at the right angle it will cut into the head and the hammering will help 'shock' the bolt loose.
You can try knocking the chisel in from opposite side to spread the hammering force.
Punch & Chisel Set
Polished chrome vanadium shafts and soft grip handles.3 piece set contains: 10mm chisel, 3mm pin punch and 3mm centre punch.www.toolstation.com
I would use some sort of cutter grinder or even a dremel tool cut a new slot across then use a large slotted screwdriver if needed then you could use the tap hard shock methodSo I rounded the head on this screw… then I buy a kit to unwind the screw… HSS set. And the FCKERRR HAS BROKEN ON ME what next ??!
Ps make sure it’s not an opposite thread ???I would use some sort of cutter grinder or even a dremel tool cut a new slot across then use a large slotted screwdriver if needed then you could use the tap hard shock method
Best of luck
howPs make sure it’s not an opposite thread ???
Don’t worry it isn’t a LH thread. Anti-clockwise to remove.
This is the one that snapped in there……
Do you know the tool bit I need to put screw them back? PLUS A NEW SCREW!!FYI ..
That bolt is this:
Triple square, or spline bolt as they call it.
But it's defo well tight.
So imact screwdriver is good to free it up.
Not sure on its re tighten tourque spec.
View attachment 183551View attachment 183552View attachment 183553
Just checked yes left hand thread
