if you snapped the extractor then the bolt will be tightly seated. You could try drilling around the mild steel head with a small drill bit to weaken then go the next size up etc.. Hopefully you’ll be left with an opportunity to get better purchase to remove it. Or tack a hex nut onto the head of the bolt?
I snapped the head off an M8 bolt when removing the rear ARB this week.. That was fun. I began drilling a small pilot hole in the bolt for extraction. That snapped inside the bolt and wasn’t removable… That was a challenge..
