I need some advice on a little problem where the pressure in one tyre (front left) drops over a couple of weeks. I first became aware when the TPMS alerted on the dash, checking the pressure with a gauge it was 10psi lower than it should have been, so I topped it up and reset the TPMS.
Almost two weeks later the same thing happened, so off to the tyre fitters. They checked for leaks in a water bath and when they couldn't locate a leak they refitted the tyre along with a new valve.
After a further couple of weeks and 300 miles the TPMS has triggered again today. I have again checked and the pressure is 10psi lower than the other front tyre which had dropped 0.5psi over the same period.
Do I have a problem or do I just ignore and keep topping up every couple of weeks? Should I get the tyre replaced?
