Not quite true- it's only passenger carrying vehicles so standard on a kombi but a paid option on a PV.
thank you........
so my new vcds will be able to enable it then...........
I was amazed my £13k Suzuki has valve sensors not the usual rolling circumference measuring. Great until I need a new tyre and KwikFit chuck them away......'Posh' vehicles have pressure sensors stuck on the rim that measure actual pressure not just rely on ABS sensor for rolling circumference
And whether or not Kwikfit code the replacement valve or notI was amazed my £13k Suzuki has valve sensors not the usual rolling circumference measuring. Great until I need a new tyre and KwikFit chuck them away......
You will have to excuse for being a bit dim, does this mean that my Highline spec panel van has TPMS but it needs activating via vcds
If only we knew could have done it while you were here, have to arrange another catchupCheers![]()
